Old 11-30-2007, 09:27 AM   #1
Allen K. Littlefield's Avatar
Question Side vent cover questions.
I am still planning on changing my '02 side vents with the separate vanes for a set of '03 or '04 ones that have the vanes cast right in. This should make the on and off of these vents in order to clean, de-snork etc. much easier since you do not seem to have to fiddle with the long attachment arms of the separate vanes on my '02 or am I off base? Also are the attachment points the same on both '02 and '03/4 or are they different? Does the passenger side vent plate detach on my model as the drivers side, I would expect so but...? I believe Grizzly did this and maybe he will have an answer. Thanks in advance,
AKL
Old 11-30-2007, 01:04 PM   #2
Wink
Answered one of my own questions when I managed to take out the pass. side vent and vanes and then replaced them. Same as drivers/intake side. Pretty clean in there and there is a rectangular passage to the fan that blows onto the engine. No debris or leaves just some dust. I wonder if the '03/04 vent has a second screw to hold it in as my '02 vent needs the vanes in place in order to hold it secure. I tried replacing it without the vanes and it kinda flaps loose on the bottom with no mounting or secure point. I will attempt a de-snork now that I know I can remove and replace the vanes and vent body (which means I haven't broken anything yet....)
AKL
Old 12-01-2007, 12:46 PM   #3
Cool De snorked
Well today I managed to de snork and it does howl a bit more when pushed into the upper rpm range. Don't know if I am getting more hp out of the mod. or not but it seems a bit more responsive or maybe I am wishing it to be so.
Unless the '03/04 side vent covers have a friction fit area at the bottom or another screw somewhere, I don't see how it will stay in place without the vanes being in place. BTW I just broke one of the vanes, top one on intake side, but it seems to be held in place by friction so it doesn't bother me.
This seems to be a conversation with my self at this point but I would like to hear from anybody that replaced the side vent cover with an '03 or '04 one and how they made it stay in place?
AKL
Old 12-01-2007, 01:33 PM   #4
haven't done the swap but yes there is a subtle difference in the side intakes from early 986s to later (lip on lower left etc.). See if you can get it to catch like the old did. If not, you should be able to line the inner lip of the new w/ some 3M foam tape adhesive to keep it in place.
Old 12-01-2007, 02:18 PM   #5
Thanks Burgman, the idea of foam tape could be an answer. I believe that Grizzly has done the change and was hoping to hear from him. I think that the shape of the '03 is the same as the '02, just the vanes are attached to the vent body and not separate so there had to be a way of keeping it in place.
AKL
Old 12-01-2007, 03:02 PM   #6
I did the swap on my EX- 01S, just buy the vents, paint em, pop them in.
Very easy
Marc Gelefsky
02 996 Carrera Coupe 6 Speed Aero
86 911 Carrera Targa
http://forums.rennlist.com/rennforum...tar14266_4.gif
EX-88 951, 87 951, 86 944na, 85.5 944na 00 Audi S4..01 Boxster S .etc..etc
Marc Gelefsky is offline   Reply With Quote
Old 12-01-2007, 03:42 PM   #7
Hey Allen,
For some reason, I didn't catch this post till a little while ago. Then, I went to the garage to take pictures of how it works. Once I got down on the garage floor, I couldn't stand back up. Hence, the delay. O.K. here's how it works:
This is what you're looking at now, right?
The '03/'04 vent has a little curved tab on the lower front corner. It holds the vent to the front and bottom. It looks like this...
When you put the new vent in, put the rear in first. Once it's in place, slide it Back as far as it will go. This will give you enough room to drop that tab behind the sheetmetal.
Once it is flush with the body, move it slightly forward and down so the tab goes behind the quarter panel at the front and bottom of the opening. Put the screw in the top and you're done.
But... while I had mine off, I put some mesh inside of the vents. I've heard horror stories of desnorkled Boxsters sucking up schmegma, particularly lit cigarettes, so I did this...
It's held on with tiny wire ties at the corners (man, that's a bad picture, sorry).
Don't worry if you don't like the mesh look. Once the vent is on the car, the mesh is nearly invisible.
Hope I answered your questions, pal.
http://i84.photobucket.com/albums/k2...izzlysmall.jpg
'97 986
Cheating Death on 19" Wheels
...no catastrophic engine failure ...yet
Grizzly is offline   Reply With Quote
Old 12-01-2007, 07:11 PM   #8
Porscheectomy
AKL
The pre-02 vent bezels have the same tab in the lower-forward corner that fit onto the fender as the post-02 that Grizzly describes. If you haven't got the tab behind the fender, it will flop around as you describe.
Old 12-02-2007, 07:33 AM   #9
Blue2000S, does this mean I should be able to replace my side vent covers on my '02 without needing the vanes in place to hold it steady? I will have to give the vent covers another look and see if I can make it secure because if I can I could add screening, ala. the Grizz, and just use the current covers. Interesting. I will have to decide if I prefer the '03 look and try to find a set, preferably in Arctic Silver, otherwise I will have to buy them new and have them painted which could get costly as the vents go for $138 ea. from Sunset unpainted. I suppose I will have to attend Hershey this spring.
AKL
Old 12-02-2007, 08:20 AM   #10
Porscheectomy
AKL
It's been a while since I've opened up the vent, but I believe you could put the bezel on without the louvers.
Old 12-02-2007, 12:09 PM   #11
Send a message via AIM to djomlas
you can, pretty much what strosek looks like i believe, just mesh piece.
do the louvers even do anything?
http://i34.tinypic.com/157yslk.jpg
"I couldn't find the sports car of my dreams, so I built it myself." ~F. Porsche
Gemballa springs::litronics::Eurotech 18s(275/225)::B&M::MOMO wheel::
exhaust cutouts::EVOcoldair intake::OEM smoked tails & sidemarkers::
colormatched bumperettes::Top Speed Pro-1 exhaust::
my cardomain/pictures page
djomlas is offline   Reply With Quote
