Old 08-26-2007, 04:22 PM   #1
Locks are screwed! wtf??
My car will lock from the inside. The transponder on the key will not work to lock the car though. I put the key in the door to lock it and it just spins and won't lock. Ummm...I can't lock my car from the outside at all.
"You finally got that Nazi-go-cart you always wanted." -Peer
http://i40.tinypic.com/ei6sns.jpg
pompous is offline   Reply With Quote
Old 08-26-2007, 05:34 PM   #2
Porsche "Purist"
Paul's Avatar
Dead battery in the key?
1987 924S. 2002 996TT. PST-2
Old 09-03-2007, 10:15 AM   #3
lol No, the battery is good in the key. Little red light is still glowing in there. Any other thoughts?
Old 09-03-2007, 10:34 AM   #4
bmussatti
Posts: n/a
Pompous, read through the section in your owners manual about how the key fob "goes to sleep" if the car sits for about 5-7 days. This is a safety feature and is tied into the alarm system. Possibly your key fell asleep.
Could still be a weak battery in the fob too. Don't let the redlight fool ya!
Old 09-03-2007, 12:09 PM   #5
I had no clue about that. thankyou! I'm gonna go down to the garage now and hopefully that will be my solution. (fingers crossed)
Old 09-03-2007, 12:16 PM   #6
Check your fuses for the central locking system.
B-8
C-3
E-1
Hope this helps.
John
szentej is offline   Reply With Quote
Old 09-03-2007, 12:46 PM   #7
Tried to reset the key and checked the fuses. No luck w/this. I can lock/unlock w/the button inside the car, but not w/the remote or the key hole still.
Old 09-03-2007, 02:32 PM   #8
Porsche "Purist"
Paul's Avatar
Tell us more about the key "spinning" when you insert it into the lock. Are you saying it is turning more than 90 degrees in either direction?
Old 09-03-2007, 03:58 PM   #9
I can turn it in circles in any direction. Like its not catching on anything.
Old 09-03-2007, 04:08 PM   #10
Porsche "Purist"
Paul's Avatar
That's the problem, something is broke in the lock mechanism and is probably confusing the electric lock system.
Old 09-03-2007, 04:10 PM   #11
...but why would I be able to lock it from inside the car with the button on the dash? Shouldn't the remote on the key still work, just not the actual key?
Old 09-03-2007, 04:30 PM   #12
Porsche "Purist"
Paul's Avatar
The outside lock needs to be fixed. Are there any marks on it that would indicate that someone tried to force it open with a screw driver? If so your insurance may cover the repair.
I'm guessing that once the lock is fixed, everything will return to normal.
Old 09-03-2007, 08:35 PM   #13
If the lock cylinder in your door does nothing but spin loosely, that's your best clue that something is wrong.
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
Old 09-04-2007, 09:05 AM   #14
I had this problem after picking my car up from service. I had to bring it back and they had to re-code some module relating to door locking.
rickhuizinga is offline   Reply With Quote
