Old 08-18-2007, 04:18 PM   #1
uneven rear tire wear.
Hello,
I have new, less than 6 month (5000 miles) old tires on the rear of my 2002 S and just noticed that the inner tread of both tires are almost worn to the point of replacement. The center and outer parts of the tire have lots and lots of tread life in them. Whats going on? Is it camber or aligment or just normal?
Thanks,
James
2002 S
jhandy is offline   Reply With Quote
Old 08-18-2007, 04:40 PM   #2
Track rat
Topless's Avatar
You must drive a lot of straight lines. An alignment shop can reduce negative camber on the rears for more even wear for your driving style.
Old 08-18-2007, 06:09 PM   #3
It's typical for insides to wear out first but if you have LOTS of tread left in middle and outside, then you should either get your alignment checked or spend more time at the track.
choeglund is offline   Reply With Quote
Old 08-18-2007, 06:27 PM   #4
Porsche "Purist"
Paul's Avatar
Could also be a toe in/out issue....
I had my aligned at the very lower limits of camber and toe and my tire wear seems to have slowed down a lot.
1987 924S. 2002 996TT. PST-2
Old 08-18-2007, 06:35 PM   #5
The Boxster is my daily driver so i guess I do drive a lot of freeway strait lines. I will try to have the alignment shop fix it up for me tomorrow. What should i tell him to put the camber and toe at for regular city and highway driving?
2002 S
Old 08-18-2007, 06:43 PM   #6
Porsche "Purist"
Paul's Avatar
You want them to set it to the minimum amount of toe and camber that the alignment specs will allow.
Most shops just put it on the machine and verify that each wheel is some where in between the max and min of each setting. You want the castor to be in the middle of the range, the camber and toe at their lowest allowable settings.
