Old 08-09-2007, 07:30 PM   #1
Smile remove negative in battery before take off door panel
does anyone know if i want to remove door panel to fix window, do i need to remove negative in Battery before i take if off?
langood is offline   Reply With Quote
Old 08-09-2007, 08:31 PM   #2
husker boxster's Avatar
Hello,
You don't mention what year your Box is, so here are 2 questions:
Do you have side airbags?
Do you want them to deploy?
Instructions #1 & #2 in Bentley for removing door trim panels:
- disconnect negative (-) cable from battery.
- wait 1 minute after disconnecting battery before working in vacinity of airbag.
If you haven't taken a door panel off the Box before, look for instructions because there are some hidden fasteners that will trip you up. You don't want to break anything. I seem to recall seeing some on the forum in previous posts. I used the Bentley manual and had no problems. You may PM me if you have questions.
Good luck.
1989 928 S4 5 spd - black
Old 08-09-2007, 09:08 PM   #3
Originally Posted by husker boxster
Hello,
Good luck.
hello, My boxster is 2000, it does have airbag on the sides.
Old 08-09-2007, 09:11 PM   #4
It's a good idea to take the cable off.... make sure you have your radio code if you still have the factory unit.
wvicary is offline   Reply With Quote
