Old 08-09-2007, 07:31 PM   #2
husker boxster
husker boxster's Avatar
Hello,
You don't mention what year your Box is, so here are 2 questions:
Do you have side airbags?
Do you want them to deploy?
Instructions #1 & #2 in Bentley for removing door trim panels:
- disconnect negative (-) cable from battery.
- wait 1 minute after disconnecting battery before working in vacinity of airbag.
If you haven't taken a door panel off the Box before, look for instructions because there are some hidden fasteners that will trip you up. You don't want to break anything. I seem to recall seeing some on the forum in previous posts. I used the Bentley manual and had no problems. You may PM me if you have questions.
Good luck.
1989 928 S4 5 spd - black
