Old 08-09-2007, 08:08 PM   #3
langood
Originally Posted by husker boxster
Hello,
You don't mention what year your Box is, so here are 2 questions:
Do you have side airbags?
Do you want them to deploy?
Instructions #1 & #2 in Bentley for removing door trim panels:
- disconnect negative (-) cable from battery.
- wait 1 minute after disconnecting battery before working in vacinity of airbag.
If you haven't taken a door panel off the Box before, look for instructions because there are some hidden fasteners that will trip you up. You don't want to break anything. I seem to recall seeing some on the forum in previous posts. I used the Bentley manual and had no problems. You may PM me if you have questions.
Good luck.
hello, My boxster is 2000, it does have airbag on the sides.
langood is offline   Reply With Quote
