Old 08-06-2007, 05:49 AM   #1
CEL with p1124 and p1126 with rough idle
Hey Folks,
I have a CEL with p1124 and p1126 with inconsistent/rough idle.
I have cleaned MAF and replaced fuel filter.
I have had p1124 in the past couple years(3-4 times), cleaned the MAF and code cleared and does not return for 6-12 months.
I have white/grey smoke on startup and above 3k RPMs....this is a new symptom.
Any ideas on next steps?
1998 boxster
62k miles
nzaldivar is offline   Reply With Quote
Old 08-06-2007, 05:57 AM   #2
two separate issues: time for a new maf and a new oil separator.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
Old 08-06-2007, 06:14 AM   #3
Send a message via AIM to djomlas
i had those as well, on a 98 with 62k, it was the MAF.
it got bad to the point where i couldn't even get the car out of the driveway.
after those i started getting 1128 and 1130, so MAF change fixed all 4 codes.
good luck
http://i34.tinypic.com/157yslk.jpg
"I couldn't find the sports car of my dreams, so I built it myself." ~F. Porsche
Gemballa springs::litronics::Eurotech 18s(275/225)::B&M::MOMO wheel::
exhaust cutouts::EVOcoldair intake::OEM smoked tails & sidemarkers::
colormatched bumperettes::Top Speed Pro-1 exhaust::
my cardomain/pictures page
djomlas is offline   Reply With Quote
Old 08-06-2007, 06:58 AM   #4
Franco's Avatar
insite
99 Boxster, M030
Hi, I agree
1997 Porsche Boxster manual
2018 Subaru WRX Sport Tech
2014 Honda CRV
2014 Mercedes Benz 350 ML
2015 Chevrolet Corvette Stingray manual
Franco is offline   Reply With Quote
Old 08-06-2007, 08:18 AM   #5
Dj,
with the MAF did you have a hrd time starting the car then after a while it would start up fro letting cooling down?
clb0099 is offline   Reply With Quote
Old 08-06-2007, 10:11 AM   #6
The car always starts fine. Just smoke and rough idle and of course error codes.
Old 08-06-2007, 10:13 AM   #7
Insite and Franco,
You are saying the AOS because of the smoke?
Old 08-06-2007, 01:21 PM   #8
Franco's Avatar
Originally Posted by nzaldivar
Insite and Franco,
HI, yes chances are the AOS is letting oil into the throttle housing, a quick verification you can do is to check for any oil around the throttle housing near the clamps and tubings located on top of engine. I would take care of the AOS first and then wait and see if you still get any codes, oil in th e throttle could set off a CEL.
Regarding the MAF, I changed mine and the car performs much better at all RPM's so if you have the cash change it and you won't regret it.
2014 Honda CRV
