08-03-2007, 08:11 AM
#1
Glass Cleaner Recs?
My windshield is spotted with what looks like mineral deposits. My standard industrial-strength glass cleaner doesn't do a thing for it. Do I need a glass-stripper or something else? Thanks.
- Jim
2000 Boxster S, Speed Yellow, Michelin AS/3 tires, 60,000 miles...
... and climbing.
08-03-2007, 08:55 AM
#2
You may be able to clay bar it and get the spots off. Are you sure you're not seeing pitting from sand and debris hitting your windshield? Mine had awful pitting in it before I swapped it out earlier this year.
Another thing you can try, tested first in an inconspicous corner (lower passenger side by base of windshield would be a good spot), would be "barkeeper's best friend," found in the grocery store isle in a "comet" style container.
This stuff is amazing. It polishes glass like no other product. Works great on wine glasses and the windows in your house too.
However, I must say that I've never tried it on a windshield and therefore you should be extremely cautious to test it before you haul off and do a big spot and find out it caused more damage than good.
08-03-2007, 09:30 AM
#3
Clay bar is a good idea. I used Klasse all-in-one on my windshield last weekend and it took off some deposits that Stoner Invisible Glass missed. If you already have Klasse it's worth a try but otherwise the clay bar is much less expensive.
2003 Boxster - Sold but not forgotten
Reason: fixed spelling
08-03-2007, 10:14 AM
#4
Thanks, guys. I'll try the clay bar first as a safe method and if it's still a problem, try the barkeeper's best friend on a small spot on my wife's side of the windshield.
- Jim
... and climbing.
08-03-2007, 11:33 AM
#5
Most often (if they're deposits and not etchings) vinegar will break them down, no problem.
08-04-2007, 04:30 AM
#6
Razor blade
08-04-2007, 12:12 PM
#7
Try Brasso polish, followed up with some Stoner Invisible Glass...
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
08-04-2007, 12:54 PM
#8
Porsche "Purist"
From www.PCA.org and John Paterek the ultimate authority on this subject.
We have foumd Wurth Zebra finish which was introduced as a lubricant for thier clay paint cleaneris incredible for removing bugs water spots and film on glass.It may not Google but we have won Restoration of the year PCA parede 2 times Pebble beach, Louis Vuitton, Amelia Island ETC using tjis product. I am a firm believer in it,it also removes hard water spotting and streaks.
John Paterek - PCA WebSite - 4/18/2005
1987 924S. 2002 996TT. PST-2
08-04-2007, 02:00 PM
#9
Guest
Good find, Paul. Here is a link to the Wurth Zebra Finish:
http://www.wurthusa.com/project/en/leftnavi/catalog/product.php?path=06.0420.jpg
08-04-2007, 02:28 PM
#10
Porsche "Purist"
Thanks for the link, I was looking for it!!
08-14-2007, 07:47 AM
#11
Thanks, all. I ended up trying vinegar first without much luck. Then I tried RandallNeighbour's suggestion for the Barkeeper's Best Friend. Using a non-scratch kitchen pad, I scrubbed lightly, but vigorously for a long time, then wiped it clean, then used the vinegar again. That did a pretty good job. It's not perfect, but it's a lot better. If I decide to go for perfect, I'll give the Wurth Zebra finish a try.
- Jim
... and climbing.
