Old 02-04-2012, 12:05 PM   #1
WTB: Boxster cigarette lighter
Mine is missing.
Belgirb is offline   Reply With Quote
Old 02-04-2012, 12:14 PM   #2
well... if you don't already have the US spec lighter/recepticle (narrower & deeper to hold plugs better)... just order the upgrade kit from Sunset Porsche. Should be < $25. Might be your only way to order a new light to being with...
Now, if you lived on the other coast, I'd say order from Suncoast but w/ Sunset in your backyard, you cannot go wrong.
Here's a link to the item on Suncoast's site
Good luck
Old 02-04-2012, 01:56 PM   #3
gomarlins3's Avatar
Mine was also missing and went to the parts place and bought a cheapy to fill the hole. Learned that the Boxster lighter is not the standard size. Found a nice replacement on eBay that is on it's way. Hopefully this fits better. If not, I will go with the kit mentioned above.
gomarlins3 is offline   Reply With Quote
Old 02-04-2012, 02:52 PM   #4
jrcui's Avatar
Sunset was cheap
I bought mine from Sunset for around $15 bucks.
jrcui is offline   Reply With Quote
Old 02-04-2012, 07:21 PM   #5
+1 Easy and cheap solution.
Old 02-05-2012, 05:17 AM   #6
WV Boxster
wvboxst3r's Avatar
Radio shack has replacements. I put in a extra power point in black on drivers side of radio.
If you don't need a lighter the power point was $7.
If your not LIVIN now, then when?
wvboxst3r is offline   Reply With Quote
Old 02-05-2012, 06:06 AM   #7
gomarlins3's Avatar
Do I need to remove the dash to replace the lighter/power point socket?
Old 02-05-2012, 06:12 AM   #8
WV Boxster
wvboxst3r's Avatar
no, the panel that the lighter is in will pop off. Start under panel with a flat head screw driver (wrapped in cloth) start prying off and working up. It is held on in middle by a post recessed in a hole. (rough explanation but you will see once it is out).
That should give you enough room to work if not then radio will need to be removed.
I was in process of radio swap and seen need for second power point since this is my portable office. I added it then and was simple.
Old 02-05-2012, 06:34 AM   #9
gomarlins3's Avatar
^Thank you sir.
Old 02-06-2012, 04:44 PM   #10
gomarlins3's Avatar
New lighter came today and it fits perfectly!!
Bought it off eBay for $21.94 shipped.
Tags
cigarette , lighter , wtn
