Old 02-05-2012, 06:12 AM   #8
wvboxst3r
WV Boxster
wvboxst3r's Avatar
no, the panel that the lighter is in will pop off. Start under panel with a flat head screw driver (wrapped in cloth) start prying off and working up. It is held on in middle by a post recessed in a hole. (rough explanation but you will see once it is out).
That should give you enough room to work if not then radio will need to be removed.
I was in process of radio swap and seen need for second power point since this is my portable office. I added it then and was simple.
If your not LIVIN now, then when?
wvboxst3r is offline   Reply With Quote
