Old 10-06-2004, 11:46 AM   #3
insite
Well, problem solved, but i still don't know where the temp sensor is. I don't think that it could possibly be located in the reservoir, as this coolant will tend to be a lot less hot than the stuff in the engine. i'm inclined to believe that the sensor in the reservoir is in fact for the coolant level. Most liquid level indicators use a tube running into the liquid with a magnet around it. the magnet floats. a pickup sensor is then inserted into the tube and uses the magnet's level to sense the liquid level. looking closer at the reservoir, it appears that this is what the reservoir sensor does.
i'd venture to guess that the temp sensor is located somewhere near the thermostat or in one or both radiators. any takers?
insite is offline   Reply With Quote
