Old 04-24-2007, 04:46 AM   #18
insite
Originally Posted by CJ_Boxster
Yeah i should add those.... even though i didnt use them myself
They are holding up very well, Now that its getting warmer outside, i can here my front control arms chattering like a mofo. That will be the next arms i buy from debulozparts.
Carlos -
FYI, the fronts don't go bad so often. the more likely culprit is the sway bar drop links. they make the same sound, but are much cheaper to replace ($55 on ebay).
if you do get the front control arms, definitely have it aligned. you can use their adustability to ensure equal caster from side to side. this is a great feature.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
