Old 04-05-2007, 06:55 AM   #6
insite
Originally Posted by c-c
I just got a set of H&R wheel spacers 7mm in the mail and they look completely different than any I have installed.
They are hubcentric and came with 2 bolts each. The spacers have a coutner sunk hole where one of the bolts goes, but it's short. Also didn't come with wheel bolts.
the bolts should be screws. they thread into the brake disks, which have small threaded holes in them for a puller tool. you will need longer bolts. i got mine from gpr tuning. you will have to take the cone washers off of your old bolts and put them on the new ones. FYI, the bolt measurement is taken from the flange of the bolt to the end of the bolt.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
