Thanks to both of you for your timely answers. I will switch the bulb tomorrow to see if that is the case. I also noticed that the tray that holds the light, the upright connector tower and the locking cam rod is held in by 3 torx screws. I imagine if worse comes to worse I could replace this tray. I will try the rear plug in as mentioned and I will try to better secure the socket to the tower with wire, tape or nylon tie strips. I will keep you posted on my "progress" in solving this matter. I am also going to cross post on PPBB, Rennlist etc. to see if anyone else has experienced this dilemma. It seems I am cursed as every time I do any work on a car I **** it up and have to solve more problems or spend more money. Arrghhh.
986****up
