Old 06-17-2020, 09:07 AM   #1
steved0x
steved0x's Avatar
Originally Posted by 99Roadster View Post
I have a question for you concerning the rear strut....Which is the best way to replace it by taking off that axle nut(The one with the 340 ft-lbs of torque) or leaving it alone and pulling out the CV unit from the transmission ?
The first time I did a suspension I took this axle nut off because I was also doing wheel bearings.
Every other time I used a custom spring compressor that I borrowed from a friend, that let me take out the rear struts without having to remove the axle nut or remove the LCA. A regular spring compressor may work especially if your original suspension is blown out and easy to compress once the spring is compressed. I think there may be a few videos out there showing shortcuts.
One I never got a chance to try would be removing the sheet metal brace and the two diagonal supports (figure 1 here), and then loosening the inner LCA, with that brace and the supports out of the way I bet that would let the LCA drop down pretty far and the strut top might slide right out
