Thread: 6 point harness
Old 03-06-2020, 07:41 PM   #7
steved0x
steved0x's Avatar
What is involved in the harness installation if I am retaining the oem belts?
You can add harnesses without impacting 3 pt belt, I run both:
Harness shoulder belts wrapped to roll hoop bottoms (height works for me)
Sub belts wrapped to sub bar mounted under the seat to the rails.
Lap belts:
Outboard, snapped into an eyebolt that I used to replace the OEM seat belt outer bolt. It is a Motorsports eyebolt from schroth
Inboard lap belt, snapped into a Brey Krause adapter that lets you mount both the seat belt receptacle for 3 pt belt and harness lap belt to the mounting point for the 3 point belt (hopefully your seat mounts have this)
I can get part #'s on Monday from my computer. If you get a 2nd set of seat belt receptacles to mount on your race seat it eases the hassle. :-)
