Originally Posted by clueless1
Yes, that info may help. If it’s just a passive antenna does that = there’s no reason I can’t just directly power it via relay? (that’s the core of the issue ... I’m not trying to “hack the immobilizer”; instead I am trying to enable/power the factory transponder antenna ON to look for a pill on remote start).
Is the passive antenna powered with constant 12V positive? And would it matter which side (which of the two wires) was powered (via relay)?
as mentioned the antenna itself is passive, but it is connected to the immobilizer module. the immobilizer module is powered by the orange wire coming from the ignition switch.
here is a diagram of the immobilizer module.
