Originally Posted by tx02
I have an 02 boxster S and am going to change the transaxle fluid. Pelican parts says the full and drain plug are both a 10mm hex socket, but here on the forum I've seen posts about needing the triple square on the 6 speed. So which is it?
If I need one for this I want to get one purchased.
Also where's a good place online to buy the Porsche gear oil?
Sunset Porsche parts is my preferred source for OEM parts.
As for the plug, it is easily visible looking at the transmission from the driver side.
You can just bend over and confirm yourself. or just listen to Steve.
