Originally Posted by rastta
Actually the cup arms are different than the regular GT3 arms - they are forged and more expensive and also have monoballs from the factory.
I'm not knocking them - but the whole idea of shims turns me off - especially when having to dial in camber.
The split arms and shim are no different than solid arms except, when your frame side eccentric bolt bottoms out you add a shim and then you regain the adjustment of the eccentrics. I use a 3MM shim on the street and a 7MM shim on track. then adjust the toe link to get your toe back in.
