Old 11-17-2017, 08:02 AM   #11
Gelbster
There are some photos of that specific issue IIRC. It is a Flag connector and a Brown wire.The wire breaks internally(insulation looks good) near the Flag connector.
My recollection is that to access this you need to remove the 2 'secret' screws behind the Steering wheel to remove the Airbag. Those screws are Torx. If they just rotate endlessly without loosening the Airbag - we both have the same problem ! I have no solution for removing the Airbag.Hopefully others will be able to suggest something.
There is a Youtube for the 'broken wire' job.
Originally Posted by Steelepuls View Post
My car did the same thing with the horn, there is a ground on the steering wheel under the airbag that was broken, the sheathing was intact but the wire underneath was broken. Undo the battery, wait a while and remove the airbag. There is a female ground connector on the steering wheel, check if it is still intact. I reconnected the ground with a new connector. Works fine now.
