You'll regret not buying a non S versions so I would only look at an S. The 2002 and older have 5 chains with more ramps that wear. Did you mean the RMS seal was replaced 43K ago.
If it was the IMS seal that means whoever pulled the cap and replace 2 o"rings but not the bearing RUN FAST.
