Old 05-17-2017, 04:47 PM   #2
Meir
1999 base
Meir's Avatar
Originally Posted by michael_J_brown View Post
The previous owner pulled the head unit out of my car and installed some JVC POS, a power amp in the front trunk, aftermarket door speakers and an aftermarket alarm system with remote kill switch.
I have removed all of this junk and will put the car back to it's original factory configuration. The speakers are easy enough to find and replace and so is the head unit. What I don't know is if the system had an amp and if so, where is it?
Anyone have any experience with the factory sound system or can point me in the right direction?
If the car had a factory amp, it should be located behind the spare tire.
Most likely it was removed, and the aftermarket one is taking his place.
If you are lucky, the installer didn't cut off the original amp plug.
I'll try to get you a pic
