Old 05-16-2017, 11:57 AM   #466
steved0x
steved0x's Avatar
Originally Posted by seningen View Post
Just picked up my Boxster after having Ben's shifter installed.
I will say it feels stiffer -- definitely a shorter throw. I'll be heading to CoTA this weekend, so I will see how it feels on track.
I think its going to take me (and maybe it) a bit of time to break in, but I can certainly see how it could be better than the stock shifter.
Mike
I've got the Function First shift handle (the older one) that can slide quite far up the shaft to put the handle closer to the wheel (the newer ones have a longer shaft on the knob, probably to resolve that issue). I used to run it much lower on my original shifter because the aftermarket boot I bought was too short and I had to run it at the lowest position. Now I just left the boot off for now, and have the knob up higher, and I really like it. I think that may have shortened my adjustment period - my throw is probably just as long as before due to the extended level length and that might be making it easier to adjust. It does feel much more solid though.
I am going this weekend to CMP, so we can both report back, hope you have a great weekend at COTA.
Steve
