yes, same tire pressure. i also took the readings when the track was about the same temp. i'm going over my logged data and other info from the day. it appears my front camber is deflecting a bit (probably bushings) and that i didn't have NEAR enough dialed in.
with the proper camber set up front, i feel confident i will see between 1.1 and 1.2G's on the track.
