			Note -if you can find Jakes comment IIRC:In this situation rotate the M96 ONLY with the Fuel Pump relay removed ! Do not pre-fill the oil filter
 On a rebuilt engine you will have lots of oil/prelube/assembly lube on vital parts and the oil pump may have been filled with Vaseline also.
 On a used engine there will be oil residue all over and at least 1+ pint can't be drained w/o removing the Bank 1 Timing Chain Tensioner anyway.
