SAI Readiness FIX
Thank you for posting this fix that worked for you. So often these threads just die when people find a solution(??) and just never bother posting which of the suggestions we made ,worked. The best part of your fix is Fast ,Simple ,Zero cost !
Now we need to keep linking your Post for future SAI victims to check how often it works. Compared to all the testing,tearing apart and drive cycle stuff ,yours is a much simpler fix!
Can you link the source you mentioned ? I'll run it by the Smog Test Tech at 'work' and post if he has any useful insights based on the source you supply.
Well done on fixing and passing - without spending lots of money!
