Old 12-10-2016, 10:01 AM   #3
thstone
The only thing you can do is start with the simple/obvious and work your way thru the codes.
P0446 EVAP Canister Shutoff Valve (Function) - Below Lower Limit
P1128 Oxygen Sensing Adaptation Area 2 (Cylinders 1 - 3) - Rich Threshold
P1130 Oxygen Sensing Adaptation Area 2 (Cylinders 4 - 6) - Rich Threshold
From the above, I'd start with checking the Evap canister shutoff valve (purge valve) and then go from there.
