Originally Posted by CrisZenithBlue
that adjusts the tension in the cable it attaches to so that the top material is stretched well. you dont want too much slack in the cables on both sides but dont think it's a good idea to have it extremely tight either because it could put pressure on the top frame and fabric.
get them adjusted but i dont think that's what makes your top snap the pushrods.
Yes. These only affect the tension when the top is up. Don't want them too tight.
I agree they aren't why the pivots are snapping. Check the synchronization between the motors. One might be closing further and applying more tension. Also make sure nothing is interfering with the clamshell coming down.
