Old 04-30-2016, 12:41 PM   #1
steved0x
steved0x's Avatar
Any tricks to reduce oversteer with limited adjustments at tbe track?
I've got new ksports installed and also have gt3 lca in front, and adjustable toe in back. I made guesses on my front camber plate, and In the front I have -3.2 camber (and no toe) and I can't take any more camber out. I have -2.2 in the back (and tiny amount of toe in) and can't get any more neg camber. I ran put of time and had to go with this setup. The back is very loose... I need to get them back even by adjusting the tops of the struts but I have to drop the struts to do it. Any tips on how to dial out oversteer through the limited changes I can do here at the track?
Then when I get home, what settings should I go for? Right now it is very loose and I don't have any confidence to push it.
I am at the center camber plate setting in back, and a little off center in front (toward the neg camber direction).
Ride heights are:
FR 616mm
FL 616.5 mm
RR 643
RL 644
So I can go.up or down with my camber settings if needed, or add height, but probably can't lower much more.
