Old 12-19-2015, 04:50 AM   #12
steved0x
steved0x's Avatar
Originally Posted by redbox986 View Post
Couple of tips when replacing: I would recommend replacing the sway bar bushings when you are in there. I did OEM Porsche, and they are not that expensive. The back ones are extremely simple to replace (they don't require the control arms to be out), but the front ones I would definitely do when replacing the control arms.
Also, I put a jack under the wheel to raise it up and get the alignment for the control arm. When doing the front, I had to turn the wheels slightly to get the alignment.
I had the "tar strip" rumbling, and it went away 100%. Good luck.
I've got new bushings ready to go in the front, backs are already replaced but fronts looked like a hassle so I have been waiting... This will be the perfect time to do them
