Originally Posted by Gelbster
Try a filter magnet hack by re-purposing old neodymium hard drive magnets ? Lots if you Google it.
Anything to reduce the amount of microscopic metal suspended in your oil is a good thing and cheap proactive maintenance.
DIY Magnetic Oil Filtering
The engine is a multitude of moving part rubbing against each other so there is bound to be some metal now and then, but if there is nothing to catch it and remove it from the oil, it will erode metal to metal parts, cause blockages and reduced oil feeding and worst case cause major failures.
"It broke because it wants to be Upgraded  "
