View Poll Results: What type of oil filter do you use
Factory - No Autocross or track use 33 55.93%
Factory - Autocross use 1 1.69%
Factory - Track use 2 3.39%
Factory - Both Autocross and track use 2 3.39%
Spinon w/ adaptor - No Autocross or track use 16 27.12%
Spinon w/ adaptor - Autocross use 2 3.39%
Spinon w/ adaptor - Track use 1 1.69%
Spinon w/ adaptor - Both Autocross and track use 2 3.39%
Voters: 59. You may not vote on this poll
Old 12-14-2015, 11:24 AM   #21
BirdDog's Avatar
Since I have a Flat-6 Innovations IMS Solution (which uses a spin on filter adapter)...
I use a Flat-6 recommended NAPA Gold filter.
2001 Boxster S - Speed Yellow, Black Leather, Tiptronic, Jake Raby rebuilt 3.2 with IMS Solution
BirdDog is offline   Reply With Quote
Old 12-14-2015, 01:12 PM   #22
Wow, 50/50 so far...I'm also highly considering the LN spin-on adapter, but my only concern is the lack of a safety/by-pass mechanism...
1998 Porsche Boxster - Ocean Jade Metallic
1985 Porsche Carrera Targa - Guards Red
1978 Porsche 911SC Euro Non-Sunroof - Grand Prix White
Seadweller is online now   Reply With Quote
Old 12-15-2015, 12:27 AM   #23
Hi,
i use the factory system. Replaced the OEM filter housing last year and allways use the OEM MANN oil filter.
Do not track the car on race tracks, but i think some windy black forest or alps roads will be more stressing for engine and brakes than Autocross.
Regards from Germany
Markus
Old 12-15-2015, 06:50 AM   #24
2003 S, Arctic Silver, M6
paulofto's Avatar
I use the stock oil filter set up with Mahle filters. The car has an IMS Guardian installed, I change my oil at 5K km and cut/inspect the filter each time as well as check the magnets on the Guardian for anything.
Old 12-15-2015, 07:27 AM   #25
Pnut's Avatar
I am NO expert, but I'm pretty sure standard, spin-on filters have bypass capability by design.
Pnut is offline   Reply With Quote
Old 12-15-2015, 07:51 AM   #26
No, not all have them, and quite plainly, they are not always either needed or useful.
Old 12-15-2015, 08:28 AM   #27
Pnut's Avatar
OK, but I didn't learn anything. When I look at my hot water tank, it's designed to let water escape the tank to relieve pressure. I'm pretty sure an oil filter bypass (whatever the design) just bypasses the filter material, correct? So, while it's not ideal to circulate unfiltered oil, it's better than starvation by blockage or loss of oil if it were to somehow escape the sealed system.
Old 12-15-2015, 08:28 AM   #28
Just for interest, what was the purpose of the oil by-pass on the flat 6?
I have the LN kit on my 99'.
1999 Silver Boxster
www.mulcahey.com
https://www.instagram.com/garymulcahey/
GaryMulcahey is offline   Reply With Quote
Old 12-15-2015, 08:41 AM   #29
The problem is that allowing unfiltered contaminated oil to circulate is just going to make an already very bad problem even worse. If your oil filter is so plugged with metal that the bypass opens, your engine is already gone and will have to come out and apart. Continuing to circulate contaminated oil is just going to tear it up more.
By far, the largest negative to bypass systems, and to the M96/97 engine in particular is that the bypass fails and none of the oil is ever filtered. And if you think this is a remote chance thing, do a search on the subject; it happens a lot with the OEM filter set up.
Old 12-15-2015, 09:21 AM   #30
Pnut's Avatar
I first heard about the LN spin-on adapter on this forum. The reasoning, as you stated, seems sound... it's a cheap safety precaution as far as I'm concerned, so I got one. I'm more curious to know about the bypass function (or lack thereof) on spin-on filters and if not having that functionality on a 986 could be considered risky practice?
Old 12-15-2015, 10:07 AM   #31
The use of oil bypass systems are a hold over from when the only oils you could buy were conventional straight weight oils, which could demonstrate high viscosity/poor flow characteristics under cold conditions. To make the engine's easier to spin over and prevent oil starvation or filter damage on cold start, OEM's used bypass valves in the oil systems. With modern multi weight full synthetic oils and pressure regulation built into oil pumps, these situations simply do not occur, making the bypass system unnecessary.
Old 12-15-2015, 11:02 AM   #32
Pnut's Avatar
ahhhh... NOW I've been school'd.
Thank you, good Sir.
Old 12-15-2015, 11:39 AM   #33
Thanks JFP! That is what I wanted to know so I can understand.
G
1999 Silver Boxster
www.mulcahey.com
Old 12-15-2015, 11:42 AM   #34
On the slippery slope
JayG's Avatar
once again, great info from JFP
2004 996 Targa Tip
Instructor - San Diego region
Old 12-15-2015, 12:40 PM   #35
G
Which is always a good thing.
Old 12-16-2015, 07:34 AM   #36
Hengst. No spin on here.
2016 4Runner TEP
Muzzle of Bees is offline   Reply With Quote
Old 12-16-2015, 11:05 AM   #37
jb92563's Avatar
Try a filter magnet hack by re-purposing old neodymium hard drive magnets ? Lots if you Google it.
Anything to reduce the amount of microscopic metal suspended in your oil is a good thing and cheap proactive maintenance.
DIY Magnetic Oil Filtering
The engine is a multitude of moving part rubbing against each other so there is bound to be some metal now and then, but if there is nothing to catch it and remove it from the oil, it will erode metal to metal parts, cause blockages and reduced oil feeding and worst case cause major failures.
