Lapister,
Hi neighbor ! I also live in Pasadena Ca. Suggest you find a good Indie to ensure you get a knowledgeable diagnosis. Parts are expensive -particularly if they aren't worn and you replace them!
If you get the car up on a rack ,heave on the suspension parts and you'll soon find any excessive 'play' or rattles.
Check the drive shaft bolts and boots while you are under there and look for coolant leaks from the water-pump!
Check oil leaks from the bell-housing.
You really need the kind of Indie who will give you a knowledgeable 'guided tour' under the car so you can see and verify issues. Many won't do this for "insurance " reasons.
