Old 09-20-2015, 10:08 AM   #3
thstone
You will need the threaded/screw in type since the hubs are threaded for the stock lug bolts.
Mine are Tarett 82mm with stock wheels. You may want to check with Tarett to be confirm the correct length with your spacers.
Just so you know, the front studs will stick out beyond the stock front wheel (they will be recessed for the stock rear wheel). This is due to the different size front and rear wheels (but same size stud for both). Some people don't like this look (and it might be minimized by using a front spacer) but I wanted you to know beforehand.
