Old 04-24-2015, 06:07 AM   #11
steved0x
steved0x's Avatar
Originally Posted by CrisZenithBlue View Post
yeah i'll give that a try most likely Friday and update.
question: no matter what position i put the vents in, the dash ones always blow air. is that normal? i mean i can set them to windscreen only or foot well only and i still have air coming out from the main dash vents. could that be a sign of the motor not working properly?
not that its a bother..
Have you ever had any bits of foam coming out of the vents? I believe the baffles within the system that direct air have holes in them covered with foam and when the foam disintegrates the air goes as if the baffles were fully open.
Steve
