Old 01-02-2015, 10:55 AM   #4
JFP in PA
Originally Posted by nmdarby54 View Post
Hi, I am in the process of replacing my IMS bearing with a new one from LN. In doing research I have not come across any info on anyone removing the bearing without the special tool from LN.. I was curious if anyone has had any success in removal WITHOUT the special tool, and if so. How did you go about removal?
It is not just a matter of getting the old bearing out, you also have to get the new one in without killing it. As some have actually gotten themselves in trouble using the correct tools but not following the correct procedure's, you would be well advised to get both the tools and instructions and do it correctly. You can always resell the tools later.
