Old 12-02-2014, 03:54 PM   #201
jsceash
jsceash's Avatar
Originally Posted by seningen View Post
Just curious to see what your post track idle pressures are? I've seen mine drop below 15psi...
I snapped my temp sender post (ugh!!! and I am reordering a sender) so I don't have temp values yet).
Mike
To answer your question I see 20 on the head and 25 on the sump.
My biggest problem was the original pressure relief 100PSI. It popped occasionally when the engine is cold UGH!!! finally put in a 125 PSI relief. I had to pull the carpet from the trunk.
