Thread: antfreeze
Old 11-14-2014, 01:47 PM   #4
jsceash
jsceash's Avatar
We have seen literally buckets full of the gel in the photo above, some of which totally plugged the radiators. When it happens, it ain't pretty, and creates much bigger hot spots than bits from the water pump impeller when it craps out.
So when you start adding another product to a system already containing Porsche coolant, regardless of what country it is made in, you have to ask yourself, "Are you feeling lucky?"
MSDS sheet comparison. The numbers that are listed are the chemical codes from an international database I believe they are identical. Could they be in differing concentration I guess. Would that make them curdle Emphatically NO.
Pentosin Pentafrost SF
Active ingredients
Ethylene Glycol (107-21-1)
Diethylene Glycol (111-46-6)
Sebacic Acid (111-20-6)
Sodium Hydroxide (1310-73-2)
Water (7732-18-5)
Denatonium Benzonate (3734-33-6)
Die and Defoamer
Porsche 000 043 301 05
Active ingredients
Water (7732-18-5)
Die and Defoamer
