Old 07-18-2014, 12:26 PM   #5
jsceash
jsceash's Avatar
Check the hose between the AOS and Plenum and the 4,5,6 bank and AOS there are 2 O-rings on each that I would replace anytime I remove that tubes. Then check the other tubes for a vacuum leak. Also the long hose between the 4,5,6 bank and AOS can get dried out and crack sometime when pulling it around.
