Originally Posted by Paseb
any recommandation?
where to buy?
where to install?
for a 2004 boxster S
thanks
You need a 6 pole switch, wired like this:
https://www.pegasusautoracing.com/pdfs/4430WiringInstructions.pdf
I wired mine so that it killed the ECU instead of the ignition. Cant remember which wire it was - I chased it back from the fuse box, but it kills the engine dead.
I bought mine from OGracing:
BATTERY KILLSWITCH KIT FOR PORSCHES
but you can probably do it cheaper if you DIY rather than buy the kit.
Mine was installed on the RHS of the battery, with the pull wire coming across the frunk and exiting beneath the drivers side windshield.
