Old 07-21-2013, 07:08 AM   #3
thstone
Is there a chance that the control unit is set in "Auto" mode? If so, then every time you start the car the controller will probably want to turn on the A/C and/or crank up the fan speed. Try manually setting the climate control to see if that helps. If not, ???
