Old 03-31-2013, 07:55 PM   #1
crumbum
HELP: Total Headlight failure
Hi guys,
I was driving home late last night, when I hit the high-beams on a dark road to get a better look at the curve coming up. Much to my shock, ALL lights went out. There I was, doing 80 in a turn on a dark road with NO LIGHTS. I frantically hit low and high beams and NOTHING. Turned the headlight switch on and off. Still nothing. When I pulled back on the high beams, it lit up. I drove like that for a little while before it occurred to me to hit the driving lights. They worked.
When I got home, I started research and this seems to be a common thing (see links below). Most folks report hitting the high beams (push forward) and then...total darkness. Most folks just replace both bulbs and they are good to go.
However, I want to know if this is a failure on the selector switch. Anybody else isolate the high-beam stalk as an issue?
http://986forum.com/forums/general-discussions/31027-head-light-issues.html
http://986forum.com/forums/general-discussions/22337-no-headlights.html
http://986forum.com/forums/general-discussions/29612-culprit.html
http://986forum.com/forums/general-discussions/22297-both-headlights-not-working.html
http://986forum.com/forums/general-discussions/14556-complete-headlight-failure.html
crumbum is offline   Reply With Quote
