Mark. you are mixing the two procedures.
no need for any bolts in the LN method.
you are ready to insert the bearing.
follow the instruction on the paper you got with the bearing, TO THE WORD!
the 3 25 mm bolts i sent you with the kit, are used to drive the cover into place once the bearing is installed.
