Old 02-06-2013, 10:23 AM   #17
Meir
1999 base
Meir's Avatar
Originally Posted by southernstar View Post
Mike, I have bills from the original owner and the engine numbers match the body (to the extent that they would denote a very early 2.7) so I feel safe in concluding that the engine was not replaced. I agree that, as engine numbers are not reliable, one is supposed to disassmble to determine whether it is a dual or single bearing. In the past this was not a problem as the ceramic bearing was available for both. Now they are only available for the earlier (double) and hence, after disassembly by my mechanic, I can only order a bearing if I have an earlier d. If not, I need to have the car re-assembled and shipped (or the engine removed and it and the transmission shipped), to and from Ontario, Canada. Or am I missing something?
Brad
as far as i know, the ceramic bearing from LN is available in both the single and the double raw configuration.
order the bearing only after the flywheel was removed, and you can see which one you need.
the "final solution" is available only for the later style single row, and contently available only at flat6.
so this way or the other, your mechanic cant do the job for you (yet).
