Old 02-06-2013, 09:08 AM   #6
jb92563
jb92563's Avatar
Originally Posted by navair View Post
My '02 S just presented with a weird problem: headlights work fine via the main switch, all fuses are good, but now the high beam stalk (forward on column) has no effect-the lights stay low; no blue indicator....yet the pull to flash DOES work, so it's not the high beam bulbs etc. I'ver searched all over here and the web, and this seems unique. Any clues???? Could it still be the main light switch (again, all park/low beam/fogs work)
I have the exact problem, no high beam except when you pull back on the stalk to flash the lights, so I know the bulbs are good.
You say it is the "Dimmer Switch" in the steering column?
Do you have a replacement part recommendation and part number?
How hard is it to replace
