Old 12-02-2012, 04:49 AM   #3
Meir
1999 base
Meir's Avatar
The clutch switch is located on the clutch pedal under the dash. It looks a lot like the brake light switch on the brake pedal. It goes bad easily and will stop the car from starting (because the clutch needs to be depressed to start the engine). Cheap and easy to replace.
This is not correct (sorry).
The switch that looks like brake switch, is used to deactivate the cruise control when pressing the clutch lever.
Ther is another switch located right next to it. It has a metal arm that can be adjusted by bending it. That wil make the clutch lever touch the switch sooner.
