Old 05-10-2012, 06:24 PM   #10
schoir
Originally Posted by ferrytrip1 View Post
If I release the pushrods at the v bar so the xmsn does not drive anything will the mechanism go full travel from open to closed - ie the xmsn does not know there is no roof attached so it would just rotate as normal and stop on the limit switches.
Thanks, Simon
YNWA
Yes, with all four pushrods disconnected, the V-levers should rotate fully and stop at each of the two limits if the microswitches inside the transmission are functioning properly.
Regards, Maurice.
schoir is offline   Reply With Quote
