Old 10-21-2011, 06:30 PM   #2
jsceash
jsceash's Avatar
Looking through the front of the lamp cover, is there a little bit of clearence the entire way around the lamp holder say abot 1/4". The lamp reflector itself is mounted on 2 white ball and sockets and one fix swivel. If the lamp is close or against the outer shell of the light one of the ball and sockets is unsnapped or loose. Remove the light fixture with the special tool in the tool kit that should be with the car. Then remove the transformer cover on the end of the lamp and snap the socket back onto the ball. If it the one on the motor it's a little more complicated, and you may have to remove the lamp and the ignitor coil to reach it. Do not handle the lamp if you have to remove it. Use a clean cotton cloth. If you touch the lamp clean it with alcohol prep pad and dry with a clean cotton cloth. Oil film on the quartz bulb can reduce it life.
