Old 07-15-2011, 07:09 PM   #1
Paul
Porsche "Purist"
Paul's Avatar
Originally Posted by BYprodriver
If you just loosen the 2 rear suspension strut to frame bolts per side you can move them to lineup the bolt holes & then push them outward as much as possible to maximize rear track width & negative camber. No matter what you do you will need to check the rear alignment settings afterward.
Thanks, I was trying to avoid a $200 alignment, but as I looked at it last night, I kinda figured that your solution was probably the best choice.
1987 924S. 2002 996TT. PST-2
