Very good looking Tony. Let me ask you and others something, do you have any 'orange peel' on the sides specifically the doors? Seems like my car has almost a pebble finish on the doors and to lesser extent elsewhere. I assume that the paint dries different on the vertical surface as opposed to the top of the hood, deck and fender tops. I have solved some of the worse with wet sandpaper then an orbital buff with 3M rubbing compound. So I wonder if this peel is more or less standard on all Boxes???
AKL
'02, Arctic Silver/Graphite Gray, 2.7, TIP, 2nd cat delete, Charlie Chan muffler,de-ambered, Braille Battery, clear tailights, painted bumperettes, clear third brake light, M030 sway bars, F shock tower braces, clear rear deck, '03 side vents.  15mm spacers fore & aft.
